Multipnysics
Posted 2013/12/29 5:42 GMT-5 Modeling Tools & Definitions, Parameters, Variables, & Functions Version 4.4 7 Replies
It is possible to connect more physical in one unit (multiphysic) so the various parts work together?
Thank you.
Well, that is what the program is about!
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
But I dont know how can I do it?
I read help but there where nothing.
Can any body help with this problem.
If I understand your question, you want to "add physics".
So when you create or have created a model, right-click on it, the first option appearing should be "add a physic" (or something like that) then left-click on it and you can add phenomenons.
Then left-click on your physic, find "dependant variables" under "physical model" and click on it and you can choose the name of your variables in order to choose the same as the first physic.
(I didn't try but it should work).
Is it it ?
(sorry, i'm using french version of comsol, so i'm not sure of the properties name, but it's probably close)
Also the documentation is extensive. You will need to spend some time with it.
You may also consider to attend a training course offered by COMSOL. This helps a lot.
The forum can help you to solve specific problems.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Sorry that still bother me but those procedures have not worked.
I will try to give an example of what my point.
I have an empty model in version 4.4.
1 I add to the model "Add physic" physics Miccrowave heating.
2, then add "Add to physics" Ac-Dc-Magnetic Field ..
In both modules is variable Bx.
But when I activate Magnetic field of microwave heating and Magnetic field of AC-DC
and launch a study compute.Model behaves as if it were two independent magnetic fields.
Thank you for your help.
P. S.
Where can I find Multiphysic description for Comsol?
I did a little search in the knowledge base using "microwave static magnetic"
This resulted in 86 hits:
www.comsol.com/search/?s=microwave+static+magnetic
one of them is:
www.comsol.com/model/dipolar-microwave-plasma-source-10512
even if you don't have the plasma module you can still have a look at the pdf:
www.comsol.com/model/download/186327/models.plasma.dipolar_ecr_source.pdf
Use your own search terms and you will probably find better suited examples. You can't expect to exactly find your case. But you will find a lot about multiphysics couplings.
Edgar J. Kaiser
www.emphys.com
