error test failures
hi
i use ccp module for simulation,my time range is range(0,5e-5,0.001) but when i compute model times go 7.579247e-019 to this and report this error
Repeated error test failures. May have reached a singularity.
Time : 7.579247088737066e-019
how can i solve it?
thanks
2 Replies Last Post 2014/09/03 21:03 JST
Luke Gritter Certified Consultant
Posted: 1 decade ago 2014/01/07 1:25 JST
Amir,
Capacitively coupled plasma models often have convergence problems due to the sheath dynamics and the large number of cycles required to reach periodic steady state. Here are a few items that can help facilitate convergence:
1) Avoid sharp corners (especially on the electrodes)
2) Use a very fine mesh everywhere the gradients associated with the sheath will appear during the solution process
3) Make sure you are using realistic electron transport coefficients and ion mobilities
Good luck!
Luke Gritter
AltaSim Technologies
Amir, Capacitively coupled plasma models often have convergence problems due to the sheath dynamics and the large number of cycles required to reach periodic steady state. Here are a few items that can help facilitate convergence: 1) Avoid sharp corners (especially on the electrodes) 2) Use a very fine mesh everywhere the gradients associated with the sheath will appear during the solution process 3) Make sure you are using realistic electron transport coefficients and ion mobilities Good luck! -- Luke Gritter AltaSim Technologies
Posted: 1 decade ago 2014/09/03 21:03 JST
See you again Mr. Gritter!
And I meet the same problem——
"Repeated error test failures. May have reached a singularity.
Time : 1.000005239532391e-007
Last time step is not converged."
The model is a dielectric barrier discharge , and the domain is a rectangle, I add the Electic Potential to the upper edge, --- will it be the sharp corners that results in the erro?
See you again Mr. Gritter! And I meet the same problem—— "Repeated error test failures. May have reached a singularity. Time : 1.000005239532391e-007 Last time step is not converged." The model is a dielectric barrier discharge , and the domain is a rectangle, I add the Electic Potential to the upper edge, --- will it be the sharp corners that results in the erro?
