Edgar J. Kaiser
Certified Consultant
2014/01/14 3:56 JST
Bryan,
efficiency is not just about memory usage. In practice it will depend on the specific problem, particularly on the solver you use. If your problem can be parallelized well and the solver is capable to comply, you won't take much benefit from a second COMSOL instance, you will even loose efficiency due to swapping.
If the process cannot be distributed on many CPUs a second instance might help.
If efficiency is really critical, I would recommend to try and benchmark several approaches.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Bryan,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
2014/01/14 4:59 JST
Thank you greatly, Edgar!
The drop in efficiency from splitting processing time was the biggest concern I had. I have read that there are diminishing returns with increasing cores, beyond some certain number (reference:
www.comsol.com/paper/download/181871/frommelt_abstract.pdf). So I may be more efficient if I could assign a single job to 4 cores, and another job to the remaining 4 cores. This paper states it is possible to address jobs to individual cores by running individual servers and running in single-thread mode, but do you have any idea if it can be done as I have stated (splitting into two multicores)?
EDIT: I know I can set the # of processors, but if I set it to 4, would this allow me to run a 2nd instance utilizing the other 4 processors? I would lose VM in this case; however, if I set it to 8, it would run the 1st instance using all 8 cores, and there would be no utility in running a 2nd instance! Seems like a lose-lose situation!
The drop in efficiency from splitting processing time was the biggest concern I had. I have read that there are diminishing returns with increasing cores, beyond some certain number (reference: http://www.comsol.com/paper/download/181871/frommelt_abstract.pdf). So I may be more efficient if I could assign a single job to 4 cores, and another job to the remaining 4 cores. This paper states it is possible to address jobs to individual cores by running individual servers and running in single-thread mode, but do you have any idea if it can be done as I have stated (splitting into two multicores)?
Edgar J. Kaiser
2014/01/14 5:54 JST
Bryan,
you have the machine. So you can simply try it. Let us know about your results. And keep in mind that different solvers will give different results.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Bryan,
Cheers
Edgar
Edgar J. Kaiser
2014/01/16 7:06 JST
SOLUTION: use batch sweeps!
This was a feature I'd never used before. After looking into it, a Batch Sweep will allow me to sweep over a parameter (setting each parameter to a separate .mph and separate job), set any number of simultaneous jobs, and evenly distribute the # of cores based on the number of simultaneous jobs (under "Batch 1" under "Job Configurations"). So for my system, I can run two jobs with 8 dedicated cores each (I misspoke earlier, I have 16 cores, not 8), or 4 jobs with 4 cores each.
It seems this is a good way for people to better utilize single-node servers that have a large # of cores, since several results on parallel computing show diminishing returns after several cores/threads.
I am in a time crunch, so I cannot perform any elaborate benchmarking. BUT, I will try to post the average simulation time/frequency of my single job/all-core vs multi-jobs/distributed cores.
-Bryan
-Bryan
