Hello Jake Bair
2014/05/08 4:07 GMT-4
If you are using a segregated solver, you can use "lower limit" to avoid the concentration dropping below zero. For an upper limit I am also looking for a solution...
2014/06/09 9:51 GMT-4
I am having the same issue. I am working with a different module (Subsurface Flow Module with Richards' equation) and I need to set an upper limit on the dependent variable, which in my case is water pressure. At t=0 water pressure over a certain boundary is negative; when its value reaches 0 I want to keep it constant, so basically I need to set 0 as upper limit.
Has anyone found a solution for this issue? I would greatly appreciate any help.
Alessia
Alessia
2014/08/07 17:17 GMT-4
My solution is to change the equation, so I calculate "-u" instead of "u". Thus when you set lower limit for -u, that's the upper limit for u, then you can use "-(-u)" in your model as the original variable.
This still doesn't solve the problem if you want to set lower and upper limits at the same time though.
9 years ago
2016/11/15 21:02 GMT-5
Hi, this is indeed the problem, one cannot set both the lower and upper limits. I am wondersing if comsol has any solution for this at this moment? Thanks in advance,
lailai
[QUOTE]
[/QUOTE]
lailai
