Laser Drilling on silicon carbide
I am trying to simulate material removal during percussion laser drilling. The laser(Heat) source must move along the depth of the hole as the material is removed. The material needs to be removed as it reaches melting temperature.
How can this be simulated? Can a moving Mesh boundary be incorporated?
Also there is a model for trepan drilling where laser pulse is moved in a circular curve. Can this be used to simulate moving laser beam along depth?
2 Replies Last Post 2015/07/23 6:49 JST
Hello Goutham
Posted: 1 decade ago 2014/10/17 18:48 JST
did u finish the simulation
how to do laser drilling model
did u finish the simulation how to do laser drilling model
Posted: 10 years ago 2015/07/23 6:49 JST
Hi Goutham,
Did you find any answer to the problem? I am kinda dealing with the same issue. Let me know if you have any suggestion.
S. H. Alavi
[QUOTE] I am trying to simulate material removal during percussion laser drilling. The laser(Heat) source must move along the depth of the hole as the material is removed. The material needs to be removed as it reaches melting temperature. How can this be simulated? Can a moving Mesh boundary be incorporated? Also there is a model for trepan drilling where laser pulse is moved in a circular curve. Can this be used to simulate moving laser beam along depth? [/QUOTE] Hi Goutham, Did you find any answer to the problem? I am kinda dealing with the same issue. Let me know if you have any suggestion. Thanks -- S. H. Alavi
