Combine multiple study runs with different parameter values
Hi everybody,
I am looking for a way how to loop a study and activate in each loop run different edge currents on different parts of the geometry. (physics: magnetic fields) At the end I would like to sum up the results (norm of the B-field) of every simulation run and plot this. I tried using the parametric sweep option but I think it doesn't allow such complex modifications. Am I wrong?
I managed to script this task using the Matlab interface but it would be nice to have it done within COMSOL in order to run the study on our cluster.
5 Replies Last Post 2014/03/17 15:56 JST
Posted: 1 decade ago 2014/01/24 23:37 JST
Alexander,
the parametric study allows to use more than one parameter and to specify the desired combinations.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Alexander, the parametric study allows to use more than one parameter and to specify the desired combinations. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 2014/01/25 1:11 JST
Hi Edgar,
Thanks for the hint. I managed to run the simulation using the parametric sweep option. But the combination of the results still seems to be tricky.
To be more specific I want to sum the expression "abs(mf.normB)" for the different parametric runs to one dataset, which then should contain ( abs(mf.normB)_(first parameter combination) + abs(mf.normB)_(second parameter combination)+ ... + abs(mf.normB)_(last parameter combination))
in order to plot, detect the minimum, ect.
Hi Edgar, Thanks for the hint. I managed to run the simulation using the parametric sweep option. But the combination of the results still seems to be tricky. To be more specific I want to sum the expression "abs(mf.normB)" for the different parametric runs to one dataset, which then should contain ( abs(mf.normB)_(first parameter combination) + abs(mf.normB)_(second parameter combination)+ ... + abs(mf.normB)_(last parameter combination)) in order to plot, detect the minimum, ect.
Posted: 1 decade ago 2014/01/25 8:09 JST
Alexander,
check what you can do with at() and with() operators. I guess with() is what you need.
Cheers
Edgar
Edgar J. Kaiser
www.emphys.com
Alexander, check what you can do with at() and with() operators. I guess with() is what you need. Cheers Edgar -- Edgar J. Kaiser emPhys Physical Technology http://www.emphys.com
Posted: 1 decade ago 2014/01/28 17:55 JST
Hi Edgar,
your advice was again very helpful and indeed a combined with() operator in the expression field allowed me to plot the desired combined expression within one plot, and to find the minimum within the volume.
Thanks very much for your fast and accurate help!
Alex
Hi Edgar, your advice was again very helpful and indeed a combined with() operator in the expression field allowed me to plot the desired combined expression within one plot, and to find the minimum within the volume. Thanks very much for your fast and accurate help! Alex
Posted: 1 decade ago 2014/03/17 15:56 JST
I have a similar problem, but do not understand the solution given.
Where and how do I use the at(), with() ?
My problem, to be precise, is I want to calculate a potential which is a function of 2 values for 1 parameter. I need the 2nd derivative of the square sum of the two solutions, but I don't know how to add. In math I need something like d(d( |E(wavelength1)+E(wavelength2)|^2,x,x).
thanks in advance,
Lars
Hi, I have a similar problem, but do not understand the solution given. Where and how do I use the at(), with() ? My problem, to be precise, is I want to calculate a potential which is a function of 2 values for 1 parameter. I need the 2nd derivative of the square sum of the two solutions, but I don't know how to add. In math I need something like d(d( |E(wavelength1)+E(wavelength2)|^2,x,x). thanks in advance, Lars
