Problem with exponents in Comsol 4.4
Posted 2014/01/30 4:21 GMT-5 Chemical Reaction Engineering Version 4.4 1 Reply
Hello everybody
I would like to give following equation in COMSOL 4a as a variable:
rNO=-A*exp(-Ea/(R*T))*cNO^0.71
where cNO is given in mol/m^3, but I want it to be unitless.
How can I do it? It seems that COMSOL does not accept it, as it has problems with the units.
I have tried using exp and log:
rNO=-A*exp(-Ea/(R*T))*exp(0.71*log(cNO))
But it gives several errors:
Attempt to evaluate real logarithm of negative number.
- Function: log
Failed to evaluate variable.
- Variable: comp1.r_NO
- Defined as: ((exp(((-Ea)/(T*R)))*(-A))*exp((0.70999999999999996*log(comp1.cNO))))
- Variable: comp1.chds.R_cN2
- Defined as: (-comp1.r_NO)
- Variable: comp1.chds.Res_cN2
- Defined as: (((comp1.cN2r*comp1.chds.u)+(comp1.chds.w*comp1.cN2z))-comp1.chds.R_cN2)
- Expression: abs(comp1.chds.Res_cN2)
- Expression: nojac(((1.4142135623730951^(1-shapeorder(comp1.cN2)))*max((((((abs(comp1.chds.Res_cN2)*0.5)*comp1.chds.xicwd_cN2)*sqrt(comp1.chds.gcgijgc_cN2))/((sqrt(eps)*(h^2))+comp1.chds.gcgijgc_cN2))-(((comp1.chds.Res_cN2^2)*comp1.chds.tauMassCr_cN2)/(eps+comp1.chds.gcgijgc_cN2))),0)))
- Variable: comp1.chds.nuh_cN2
- Defined as: nojac(((1.4142135623730951^(1-shapeorder(comp1.cN2)))*max((((((abs(comp1.chds.Res_cN2)*0.5)*comp1.chds.xicwd_cN2)*sqrt(comp1.chds.gcgijgc_cN2))/((sqrt(eps)*(h^2))+comp1.chds.gcgijgc_cN2))-(((comp1.chds.Res_cN2^2)*comp1.chds.tauMassCr_cN2)/(eps+comp1.chds.gcgijgc_cN2))),0)))
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.chds.crosswind@VDN${test@8}
- Defined as: (-(((comp1.cN2z*comp1.chds.gijrz)+(comp1.cN2r*comp1.chds.gijrr))*comp1.chds.nuh_cN2))
- Expression: d((2*comp1.chds.crosswind*pi*r)*(dvol),{test@8})
Best regards
Unai De La Torre
- Function: log
Best regards
Unai De La Torre
1 Reply Last Post 2014/01/30 7:17 GMT-5
