2014/02/10 6:34 GMT-5
In wich dimension do tou design your heater? 2d-axy
Do you use Coil domain?
Tell us more
Julien
Tell us more
Julien
2014/02/10 7:02 GMT-5
hello sir,
I have designed the model in 3D, using different rectangle and then making union of those all to form the complete model.sir my query is that, i have to determine the power consume by the model, so that i can make changes accordingly for better result. I have not taken thermal expansion physics for the model.so you kindly direct me how i calculate the power consumption so able to plot graph between power consumption vs. temperature that the heater is heating.
thanks
Stitaprangya Dash.
hello sir,
thanks
Stitaprangya Dash.
2014/02/10 7:16 GMT-5
Ok in 3D,
Your study is a frequency domain (AC excitation)? Stationnary(DC)?
do you use a single turn coil domain?
How do you excite the heaters?
Ok in 3D,
2014/02/11 1:47 GMT-5
Sir my study is based on stationary(DC) & I have used single turn coil domain.I supplied 0.2v at one of the terminal of the heater and made other terminal ground in ac/dc module .Then in the heat transfer module i added the heat source and temperature physics to the model.The model is running successfully but how will i determine how much power does heater consume.
2014/02/11 2:23 GMT-5
If you use a single turn coil, you can measure the power with a global evaluation
derived values-> global evaluation -> mf -> coil parameters -> coil power
You can check this value with a boundary integration of your heaters
The transfert is done by radiation, you can measure the radiative heat flux over all the boundaries,
Coil power and the sum of radiative heat fluxes must be very close
Julien
Julien
