rigid solid 2D axisymmetric
I have created a 2D axisymmetric and I want to make one of the elements a rigid solid. However I cannot find the option in the right-click menu of the physics node. It usually is in domains in a 3D model but here there is not that option.
Thank you
2 Replies Last Post 2014/03/13 23:33 JST
Posted: 1 decade ago 2014/03/07 16:16 JST
This design is intentional.
A rigid body in an axisymmetric problem has only one degree of freedom: translation along the Z-axis. So when weighing the usefulness against the possible confusion it could cause, we decided to not to add Rigid Domain and Rigid Connector in axisymmetry.
If you (or someone else) disagree, please comment in this thread, and we can reconsider.
Henrik
Hi, This design is intentional. A rigid body in an axisymmetric problem has only one degree of freedom: translation along the Z-axis. So when weighing the usefulness against the possible confusion it could cause, we decided to not to add Rigid Domain and Rigid Connector in axisymmetry. If you (or someone else) disagree, please comment in this thread, and we can reconsider. Regards, Henrik
Posted: 1 decade ago 2014/03/13 23:33 JST
Thanks for the quick response.
I have solved it and I want to post it just in case someone else is facing the same problem.
I define a point in the geometry, a point which is going to move with the rigid solid (in the symmetry axis).
In definitions, I define an integration in that point.
I add a prescribed displacement in the solid rigid, restricting the movement in the r direction and forcing the z displacement to be the point´s displacement obtained as intopxx(w).
Hope it is right and useful.
Thanks for the quick response. I have solved it and I want to post it just in case someone else is facing the same problem. I define a point in the geometry, a point which is going to move with the rigid solid (in the symmetry axis). In definitions, I define an integration in that point. I add a prescribed displacement in the solid rigid, restricting the movement in the r direction and forcing the z displacement to be the point´s displacement obtained as intopxx(w). Hope it is right and useful.
