capturing small rise in temperature
Posted 2014/03/11 1:56 JST Heat Transfer & Phase Change Version 4.4 2 Replies
I have a rectangular block where I have assigned a heat source (W/cm^3). My ambient temperature is 25 deg. First I assigned a high thermal load and recorded the peak temperature. Then I reduced it by factor of 10 and recorded the temperature again. After reducing it few times, I plotted the peak temperature. Initially, the temperature came down linearly then after a threshold , the peak temperature remained stuck at 25.1 deg.
This does not make scene. Is there a way I can increase the model sensitivity at extremely low thermal load.
Susant
Susant
2 Replies Last Post 2014/03/20 3:44 JST
