Nagi Elabbasi
Facebook Reality Labs
2014/03/18 11:38 JST
HI,
You should set up a Prestressed Analysis – Frequency Domain . That probably requires the Structural Mechanics Module. One challenge in this type of problems is to select a material model that has a dynamic stiffness (storage and loss moduli) that closely represents that of your rubber material.
HI,
2014/03/19 3:55 JST
Thanks for your answer. I guess that one of the issue is to, firstly, make the pre-stress, using some hyperelastic material (Mooney-Rivlin), and secondly calculate the frequency response using a viscoelastic material (Boltzmann's relaxation model). But what is the procedure to model a material in 2 steps (stationary and then frequency) and have a different material model for each step?
Regards
HI,
Regards
[QUOTE]
HI,
[/QUOTE]
Nagi Elabbasi
2014/03/19 11:37 JST
There is a pre-defined analysis type for this in COMSOL called “Prestressed Analysis – Frequency Domain”. Regarding switching materials between the two studies/steps it is possible and in some cases it is the most suitable way. However, you lose the benefits of the pre-stress analysis since the new material is no longer in equilibrium at the start of the frequency response step.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
