Opening a MATLAB generated geometry in COMSOL 4.3
Good morning,
Due to the necessity of loops, I have connected my MATLAB with COMSOL via LiveLink (sing the COMSOL Server). From the matlab specturm, everything works: I included all the COMSOL MLI files, and can run COMSOL commands and scripts and get an answer for studies.
What I want to do is see if there is a way to get COMSOL to open the .m file. Mostly, I want to be able to see the geometry that I've generated with the MATLAB file.
How can I achieve this?
2 Replies Last Post 2014/06/04 19:33 JST
Posted: 1 decade ago 2014/03/30 3:08 JST
Nevermind, I found the MATLAB mphsave() command in the API reference.
Posted: 1 decade ago 2014/06/04 19:33 JST
Hi Andres, how did you solve the problem?
I tried the option of export and import a model (from comsol to matlab and viceverse) by using the Client Server. when I do that it appears a message: "Problem: timeout on connection attempt". And I couldnt open my model inmatlab.
I can save my model as ".m" and open it in Matlab but after that I could not modify it and reopen in comsol, I have tried to include the sentence: mphsave ('model') but it does not work.
Thanks in advance.
Hi Andres, how did you solve the problem? I tried the option of export and import a model (from comsol to matlab and viceverse) by using the Client Server. when I do that it appears a message: "Problem: timeout on connection attempt". And I couldnt open my model inmatlab. I can save my model as ".m" and open it in Matlab but after that I could not modify it and reopen in comsol, I have tried to include the sentence: mphsave ('model') but it does not work. Thanks in advance.
