Cesare Tozzo
COMSOL Employee
2014/03/31 18:41 JST
Hi Abdu
as I started explaining from support, COMSOL can couple Electromagnetics and Deformable structure in many possible ways depending on the kind of coupling.
If the electrical part is nearly static the "electromechanics(emi)" interface is perfect (there you use a V formulation - it is a very common approach in capacitative actuator MEMS - one reference among the many available
www.comsol.com/model/biased-resonator-models-3d-11748 ). If you would like to see low frequency (rule of thumb: wavelenght of the EM wave, c_const/freq, much longer than the system) a similar approach may still be proficuously used.
On the other hand, if you ask about coupling EM wave propagation to deformable structure, you need different electromagnetic formulations which can simulate EM wave (a V formulation cannot describe a propagating field); those formulation are present in RF Module or Wave Optics Module of COMSOL and can be coupled with deformable structure (one reference among the several available
www.comsol.com/model/electromagnetic-and-structural-analysis-of-a-microwave-filter-on-a-pcb-4461 ).
Finally I would strongly suggest to update to most recent 4.4 version.
I wait for you feedback from the support channel.
Cesare
Hi Abdu
If the electrical part is nearly static the "electromechanics(emi)" interface is perfect (there you use a V formulation - it is a very common approach in capacitative actuator MEMS - one reference among the many available http://www.comsol.com/model/biased-resonator-models-3d-11748 ). If you would like to see low frequency (rule of thumb: wavelenght of the EM wave, c_const/freq, much longer than the system) a similar approach may still be proficuously used.
On the other hand, if you ask about coupling EM wave propagation to deformable structure, you need different electromagnetic formulations which can simulate EM wave (a V formulation cannot describe a propagating field); those formulation are present in RF Module or Wave Optics Module of COMSOL and can be coupled with deformable structure (one reference among the several available http://www.comsol.com/model/electromagnetic-and-structural-analysis-of-a-microwave-filter-on-a-pcb-4461 ).
Cesare
2014/04/01 2:02 JST
Grazie a te Dr. Cesare!!
I understand what you mean to some extent. I will try to understand those example simulations and will try to with my best first. If I come across difficult errors, then I will contact with you.
ciao e buona giornata !!
Abdu
Abdu
