Visualizing total displacement as a function of frequency
Posted 2010/04/01 7:47 GMT-4 7 Replies
I'm using 3D Solid, Stress-Strain (smsld) module.
Some restrictions:
a) I can't use the "Point evaluation" since the maximum of total displacement is in different place at different frequencies, and also is never at the edges in this model.
b) I know I could use slices, but they're hard to read especially when I'd want to have numerous different frequencies shown in the same picture.
c) I can't use matlab, since my PC has issues with it. (just wouldn't work with my 64 bit vista)
Thanks for any responses in advance.
there is another discussion here on the min max (try a search) the conclusion was (if I remember right) that currently it's not possible without matlab in V3.5a. It will come in V4 though.
You have the min-max postprocessing feature for plots, but that is not fully what you want.
By the way note that the eigenfrequency displacements are only qualitative (not absolute), dues to their normalisation
It's fine if the displacement values aren't absolute as long as they can be compared. I can just examine how big the displacement is at a eigenfrequency, and compare it to the other frequences I'm interested in. (i.e. if it says 1m at 500 Hz, and 1mm at 550 Hz it's already great amount of information)
BR,
Marcin Hurkala
then probably the mass participation factors are of better use, unfortunately the way COMSOL normalises the eigenvectors these are not directly there as with most other FEM pogrammes.
But if your model is simple enough you can calculate them (need matlab though) there is another thread on the forum with all the code, try a search with
"Matlab script for effective modal mass extraction"
Unfortunately Matlab isn't (currently) an option, but I'll try to keep that in mind in case they'll release new version that is more compatible with Vista 64.
BR,
Marcin Hurkala
I'm not the IT specialist in 64 it (trying to keep away from it as it catches to much of my time ;) but we use both software on UX and Vista here so it's possible
BR,
Marcin Hurkala
we have a mix of about everything with matlab (because of prising issues , it would be much easier if we could get a reasonnale deal with them, they lack obviously a good competitor), fixed & floating, 32&64 bit, UX differnt blends, MS XP, Vista, even W7 now, on old R14 up to latest 2009, but I have managed to leave off installations for the last 5 years, and I do not want to start again ;).
The only thing I'm not using is in fact MSVista 64 with COMSOL&matlab, because I'm well served so far in UX64.
But next on my list is a dual boot UX/MS-64 workstation for COMSOL+matlab+Solidworks so I can mix and get te best of all (MS for CAD-Comsol, UX for heavy duty COMSOL), so your issue might come up then, we will see.
