Problem in Global Equations defined variable
Posted 2014/04/07 19:43 GMT-4 Structural Mechanics 2 Replies
Hi all,
Does anybody know how to fix this? I am simulating a cavity filled with incompressible fluid under external pressure. Following the COMSOL Blog: www.comsol.com/blogs/computing-controlling-volume-cavity/, I used the global equations to define a pressure load "Inner_pressure" to the inner wall of a cavity beam. The global equation is set to find out whatever value of "Inner_pressure" only if it can satisfy the constraint that the cavity's volume is always the same to undeformed state. I tried this method in 2D successfully, but in 3D it has a error like this.
Failed to find a solution.
Singular matrix.
There are 1 void equations (empty rows in matrix) for the variable comp1.Inner_pressure.
at coordinates: (0,0,0), ...
Singular matrix.
2 Replies Last Post 2017/06/27 14:46 GMT-4
