COMSOL help needed. (RF module - Heating of water using waveguide)
Posted 2014/05/21 10:01 GMT-4 RF & Microwave Engineering, Modeling Tools & Definitions, Parameters, Variables, & Functions, Results & Visualization, Studies & Solvers Version 4.3b 13 Replies
I am a relatively new COMSOL user who is in the process of validating a paper, to be able to get a better grasp at COMSOL.
The paper I am trying to validate using my simulation can be found here:
dspace.library.tu.ac.th/bitstream/handle/3517/1816/3/Waraporn_Experimental-1816.pdf?origin=publication_detail
On page 547.
I want to use a wave guide to send microwaves in the TE 10 mode to the water body in an air container.
The water body exhibits dielectric loss, The equations are found in table 1 page 550.
I have followed the microwave over(potato) model and feel like I've set up everything appropriately, however when I conduct the study the results indicate that the water body is not heating, perhaps there is a mistake in the way I defined the physics.
I've been trying to crack my head around this, but have had no luck.
In the attachment I've included my model. The paper also describes the boundary conditions in page 547.
The result I wish to achieve is the graph in page 553( Fig. 11 )
Any help or words on this matter will be greatly appreciated.
Kind regards,
Mohammed
Shouldn't that be enough?
However there is no difference in the results obtained. The water body seems to be not heating up at all.
Nonlinear solver did not converge.
In segregated group 1:
Time : 10.02836128938059
Segregated group 1
Undefined value found.
Undefined value found in the stiffness matrix.
For mesh-case 1 there are 316 equations giving NaN/Inf in the matrix rows for the variable mod1.E10.
and similarly for the degrees of freedom, NaN/Inf in the matrix columns.
This should not give you any errors.
However the results as you can see if you go to study are incorrect.
I tried to use the rf waveguide model, to try and simulate this situation.
Everything runs and simulation converges now, however the results are impossible..
in 60 seconds the maximum temperature reached is 120 degC..
Perhaps there is something wrong with the physics again.
Another thing that I noted is if I change from loss tangent to relative permittivity in the microwave model physics, my solution does not converge(doesnt give me an error but keeps runnign, I left it on for 2 nights..)
Any help would be greatly appreciated.
Edit: I have included in the attachment the new model.
What is the purpose of Port 2?
Suggested Content
- KNOWLEDGE BASE Performing a Mesh Refinement Study
- BLOG Why Does a Microwave Heat Food Unevenly?
- KNOWLEDGE BASE Selecting Hardware for Clusters
- FORUM help needed
- FORUM Help needed with comsol
