error: may have reached singularity
what is meant by this error"repeated error test failures, may have reached singularity" and at what place does the error come from? from mesh, geometry, or what? i try to model DC Discharge plasma jet model
2 Replies Last Post 2014/05/25 12:15 JST
Posted: 1 decade ago 2014/05/25 12:12 JST
"Repeated error test failures. May have reached a singularity.
Time : 7.299997707294361e-006 Last time step is not converged."
I have moved the toy electrostatics ES example (circular plate capacitor) over to EC. Warning: zero AIR conductivity will cause bizarre numerical errors in the field system without any warning. Make sigma small but finite!
I apply a step voltage pulse at 4us to terminal. computes OK.
I apply a pulse on at 4us, off at 7us I get the error. Takes 10 minutes to fail.
revert to step voltage computes OK.
I have looked here. I have looked in help. Can't find anything meaningful. I have no clue what to do about it.
thanks
Colin Hales
"Repeated error test failures. May have reached a singularity. Time : 7.299997707294361e-006 Last time step is not converged." ============================ I have moved the toy electrostatics ES example (circular plate capacitor) over to EC. Warning: zero AIR conductivity will cause bizarre numerical errors in the field system without any warning. Make sigma small but finite! I apply a step voltage pulse at 4us to terminal. computes OK. I apply a pulse on at 4us, off at 7us I get the error. Takes 10 minutes to fail. revert to step voltage computes OK. I have looked here. I have looked in help. Can't find anything meaningful. I have no clue what to do about it. thanks Colin Hales
Posted: 1 decade ago 2014/05/25 12:15 JST
.MPH file is attached.
Meshes and solutions stripped)
.MPH file is attached. Meshes and solutions stripped)
