Node number
Hi everyone,
I'm solving a weak form problem on a membrane geometry. I meshed the geometry using "Free Triangular". Then solve the solution. Based on the solution, I calculated two derived values: (1) sqrt(u^2+v^2+w^2) which is the displacement and does not involve any derivatives (2) some quantity involves using "dtang()", which is tangential derivatives on the boundary.
I tried to export these two scalar fields to txt files, but I found that the node numbers in the two txt tiles are totally different.
scalar field (1)
% Model: test_case.mph
% Version: COMSOL 4.4.0.248
% Date: May 29 2014, 15:13
% Dimension: 3
% Nodes: 428----------------------------------- the node number is 428
% Expressions: 1
% Description:
% Length unit: m
scalar field (2)
% Date: May 29 2014, 16:28
% Dimension: 3
% Nodes: 512----------------------------------- the node number is 512
% Expressions: 1
% Description:
% Length unit: m
I'm using the same mesh, why the node number is different? Is is because (2) use "dtang()"?
Thanks a lot.
0 Replies Last Post 2014/05/30 9:29 JST
Hello Jiacheng Wu
