Calculating the Hessian Matrix and Eigen Values
I am using the tutorial "Pacemaker Electrode" in COMSOL 4.4, which gives me the voltage field in a 3D volume (cylinder) induced by electrical stimulation.
I figured out how to extract the voltage values in a CSV file, as well as the second spatial derivative in particular directions (d(d(V,x),x)).
Now, I would like to compute the hessian matrix at each point and the maximal eigenvalue of each of these Hessian Matrices, where each point is taken on a uniformly spaced grid. How can I do that?
I was thinking to export 6 different values (d(d(V,x),x),d(d(V,x),y),d(d(V,x),z),d(d(V,y),y),d(d(V,y),z),d(d(V,z),z)) in a file, and then import these values in Matlab, where I can fabricate the Hessian matrix. Then I would calculate the largest eigenvalue of each matrix in Matlab.
Do you have other suggestions to calculate these Hessian Matrices and Eigenvalues directly in COMSOL, or is this the best way to go?
Thank you in advance for your help.
Julien
1 Reply Last Post 2014/06/23 19:51 JST
Sven Friedel COMSOL Employee
Posted: 1 decade ago 2014/06/23 19:51 JST
Hi Julien,
there might be better ways of doing that but to give a poroper recommendation I would need to see your model - can you send it?
Sven
Hi Julien, there might be better ways of doing that but to give a poroper recommendation I would need to see your model - can you send it? Sven
