Deformed geometry model converges until I try to use the lagrange multiplier
Posted 2014/06/18 17:59 GMT-4 Heat Transfer & Phase Change, Geometry, Mesh, Studies & Solvers Version 4.3b 2 Replies
I'm trying to model the growth of a cavity in a block of ice in response to a flow of hot air. I have a model that works fairly well, with conjugate heat transfer and a deformed geometry to track the air / ice interface as melting progresses. At least, it works fine as long as I prescribe the melting rate at a fixed value of 0.001 m/s. In order to simulate melting I followed the approach of the Tin Melting Front example "Stefan problem" model: set the boundary temperature as a weak constraint, and use the lagrange multiplier as input to a prescribed normal deformation on that boundary.
The problem is that whenever I switch from the fixed value to the "Stefan problem" expression for the Prescribed Normal Mesh Velocity, my model no longer converges -- it says:
Nonlinear solver did not converge.
Time: 0
Attempt to evaluate real square root of negative number.
The model is attached. Thanks in advance for any advice!
Aaron
Hello Aaron Curtis
