Difference between setting a pressure under "Initial Values" vs "Inlet" nodes
Posted 2014/06/27 3:44 JST Computational Fluid Dynamics (CFD) 1 Reply
Hello all,
I am running a Laminar Flow, Stationary Study and have a domain with two inlets. I would like to set the initial pressure in both inlets to be X [Pa] before the simulation begins. Should this pressure value be specified under the "Initial Values" or "Inlet" node under Laminar Flow? What is the difference between the two nodes? Does the "Inlet" pressure specify what the pressure is IN the domain, whereas the "Initial Values" specify what the pressure is coming INTO the domain (i.e. at the inlets)?
1 Reply Last Post 2014/06/27 16:47 JST
