Difference between version 4.2a and 4.4, especially consider the Solid Mechanics module
Posted 2014/06/28 5:02 GMT-4 0 Replies
I have one COMSOL file was build with COMSOL 4.2a used Structural Analysis>>Solid Mechanics module. The problem is there is one warning under Solid Mechanics node and when I run it in COMSOL 4.4 , it always gives me error. The warning is: "COMSOL now always assumes that displacements control the spatial frame". and reccommand me to look at the Knowledge Base 1156.
I have did some changes to the frame setting, but still the warning and error after run a while.
It seems this is the discompatability between the version 4.2a and 4.4. I hpe some one give some suggestions and hints, thank you in advance !!
Abdu
Hello Aimaiti Rehemanjiang
