Edgar J. Kaiser
        Certified Consultant
                                2014/07/07 13:47 GMT-4
                                                    Hi Derek,
COMSOL is based on finite elements, nothing else.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
                            Hi Derek,
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
                                Jeff Hiller
        COMSOL Employee
                                2014/07/15 9:03 GMT-4
                                                    COMSOL uses finite elements primarily but not exclusively.
Per
www.comsol.com/comsol-multiphysics , "Several different methods are used in the add-on modules, including finite element analysis, the finite volume method, the boundary element method, and particle tracing methods, but the emphasis of COMSOL Multiphysics is on the finite element method."
Per http://www.comsol.com/comsol-multiphysics , "Several different methods are used in the add-on modules, including finite element analysis, the finite volume method, the boundary element method, and particle tracing methods, but the emphasis of COMSOL Multiphysics is on the finite element method."
                                Edgar J. Kaiser
                                2014/07/15 9:29 GMT-4
                                                    Hi Jeff,
interesting, I haven't come across that. So coming back to the original poster's question: is it somewhere visible, which method is used in which application case? Is the documentation providing this information?
Edgar
Edgar J. Kaiser
www.emphys.com
                            Hi Jeff,
Edgar
Edgar J. Kaiser
                                Jeff Hiller
        COMSOL Employee
                                2014/07/15 10:12 GMT-4
                                                    Yes, it does. For instance, the Semiconductor Module offers both finite element and finite volume discretizations, and you will find this documented in that module's User's Guide, version 4.4, on page 22 and following, along with a discussion of when to use one formulation versus the other and how to see which is used inside the GUI under the Discretization tab.
