Model convergence dependent on mesh quality, confused!
Posted 2014/07/08 5:57 JST RF & Microwave Engineering, Mesh, Studies & Solvers Version 4.4 4 Replies
Hi all,
My COMSOL model only solves when the mesh size is "above" the predefined Normal size. When I increase the mesh resolution to "Fine" or higher, the step BiCGStab in the progress tab stalls at around 96%, and continues iterations forever until infinity trying to converge.
I'll describe the model briefly in this paragraph, and include an attachment of it. I'm simulating a very small, simple, conductive, flattened-conical tip (sliced in half vertically for symmetry) that radiates microwave (~6GHz) energy into the surrounding region via a coaxial lumped port. I'm using the Electromagnetic Waves, Frequency Domain physics module. The model behaves exactly as desired when the lower-limit of mesh quality is met, but endlessly iterates otherwise. I've tested varying the geometry and size of the tip to no avail. It seems that the minimum element size I can reach before causing non-convergence is about 3e-7 meters. (My model size is on the order of 1e-6 meters).
I'm so confused; there's obviously nothing wrong with the model setup/geometry/physics, because it solves for lower-quality meshes. Is this a computer memory problem? (I've got 8GB). Is there a lower-limit to element size / calculation in the [EMW, Frequency Domain] module that I've reached?
Thanks for the help.
Jon Michelson
Jon Michelson
4 Replies Last Post 2014/07/10 23:32 JST
