2014/07/10 22:45 JST
If you know the percentage of solar radiation that is absorbed by your surface, and the solar radiation power per surface area you can just use a single cube (your satelite), and add a Heat Flux boundary to the face that is irradiated by the sun.
2014/07/30 18:56 JST
basically I want to do it with whole satellite which includes all electronics subsystem, its size is about 10x10x10cm small satellite. what is the solar radiation power per surface area?? if you dont mind please explain me
2014/07/31 0:10 JST
Light carries a certain amount of energy. If this is absorbed by a surface, this energy is usually transformed into heat. The radiation power per surface area is the amount of energy in the sunlight that strikes a unit surface area per unit time. This power is different for different wavelengths (
en.wikipedia.org/wiki/Sunlight#mediaviewer/File:Solar_Spectrum.png). Not all of this power is absorbed by the surface however, actually, most of it is reflected by a lot of metals. The percentage of the power that is reflected also depends on the wavelength (see for example
en.wikipedia.org/wiki/Reflectivity#mediaviewer/File:Image-Metal-reflectance.png). So if you want to do it correctly you need a graph of the absorbance as a function of wavelength of the material that you are using, and multiply it with the solar spectrum outside the atmosphere, and then integrate over all wavelengths to know the total amount of heat generated per second and per unit surface area of your satellite.
Light carries a certain amount of energy. If this is absorbed by a surface, this energy is usually transformed into heat. The radiation power per surface area is the amount of energy in the sunlight that strikes a unit surface area per unit time. This power is different for different wavelengths (http://en.wikipedia.org/wiki/Sunlight#mediaviewer/File:Solar_Spectrum.png). Not all of this power is absorbed by the surface however, actually, most of it is reflected by a lot of metals. The percentage of the power that is reflected also depends on the wavelength (see for example http://en.wikipedia.org/wiki/Reflectivity#mediaviewer/File:Image-Metal-reflectance.png). So if you want to do it correctly you need a graph of the absorbance as a function of wavelength of the material that you are using, and multiply it with the solar spectrum outside the atmosphere, and then integrate over all wavelengths to know the total amount of heat generated per second and per unit surface area of your satellite.
Jeff Hiller
COMSOL Employee
3 years ago
2022/11/09 22:52 JST
Updated:
3 years ago
2022/12/22 6:04 JST
One of the major new features of the Heat Transfer Module for version 6.1 is its Orbital Thermal Loads interface for Spacecraft thermal analysis. This blog post presents it in good detail. You will find more information on the Heat Transfer Module at this link.
Jeff Hiller
One of the major new features of the Heat Transfer Module for version 6.1 is its Orbital Thermal Loads interface for Spacecraft thermal analysis. This [blog post](https://www.comsol.com/blogs/computing-orbital-heat-loads-with-comsol-multiphysics/) presents it in good detail. You will find more information on the Heat Transfer Module at [this link](https://www.comsol.com/release/6.1/heat-transfer-module).
3 years ago
2023/01/05 22:12 JST
Hi, in cubic satellite for every surface(+X,-X vs. ) how we learn absorbed heat flux by COMSOL,
