Parametric Sweep gives different results with separate calculations
Posted 2014/07/11 17:00 GMT-4 Parameters, Variables, & Functions, Studies & Solvers Version 4.3a 1 Reply
Strange things happened when I use Parametric sweep function today. Initially, I solved a model by setting a parameter as a fixed number ( say "a"). Then I swept this parameters with different values (say "a", "b" , and 'c"). Both calculations converged but when I checked the results, the one from separate calculation ("a" only), is different from the one (with same parameter value "a") obtained from parametric sweep.
I checked several times and redid the modeling for couple of times, but do know the reasons.
Someone also encountered similar problems? Which results should I trust and what might be the reason?
Please advice,
Thanks!
Please advice,
Thanks!
1 Reply Last Post 2014/07/14 7:06 GMT-4
