Changing the material's Phase (state)
I am working on laser machining of metals and I am trying to model the process by COMSOL. What I have done is thermal modelling which shows the temperature distribution in the sample. I am wondering if it is possible to change the solid to melt when the T reaches Tm? and also same procesure for Tv? Is there anyway to define the Temperature dependent geometry and physics (I have to study the fluid flow when when the materials is molten)?
I will appreciate any help or tip.
H. Alavi
5 Replies Last Post 2016/02/09 3:26 GMT-5
Erik Bornhöft COMSOL Employee
Posted: 1 decade ago 2014/07/21 11:20 GMT-4
Dear Habib,
one option is shown in the following example model:
www.comsol.de/model/tin-melting-front-6234
Another option can be to define the material parameters temperature dependent with a (continuous) jump at the melting point and then solve for convection/flow even when the material is solid in reality. In your model it could just have a very high viscosity so it is approximately solid and shows no movement. Keep in mind a volume heat source/sink to consider latent heat might be necessary.
Check also for conference paper about this topic:
www.comsol.de/papers-presentations?q=melt%20metal
Erik
Erik Bornhöft
Senior Technical Sales Engineer
COMSOL Multiphysics GmbH
Robert-Gernhardt-Platz 1
37073 Göttingen
Deutschland
Knowledge Base:
www.comsol.de/support/knowledgebase/browse/900/
COMSOL Blog:
www.comsol.de/blogs/
Dear Habib, one option is shown in the following example model: http://www.comsol.de/model/tin-melting-front-6234 Another option can be to define the material parameters temperature dependent with a (continuous) jump at the melting point and then solve for convection/flow even when the material is solid in reality. In your model it could just have a very high viscosity so it is approximately solid and shows no movement. Keep in mind a volume heat source/sink to consider latent heat might be necessary. Check also for conference paper about this topic: http://www.comsol.de/papers-presentations?q=melt%20metal -- Best regards, Erik ********************* Erik Bornhöft Senior Technical Sales Engineer COMSOL Multiphysics GmbH Robert-Gernhardt-Platz 1 37073 Göttingen Deutschland Knowledge Base: http://www.comsol.de/support/knowledgebase/browse/900/ COMSOL Blog: http://www.comsol.de/blogs/
Posted: 1 decade ago 2014/07/21 22:24 GMT-4
Erik,
Thanks for comments. I have read the tin-melt front, but It is a little bit different with my case. I want to eliminate the elements of my geometry physically ( i.e: to show formation of the hole). It is kinda complicated but I think is doable.
H. Alavi
Erik, Thanks for comments. I have read the tin-melt front, but It is a little bit different with my case. I want to eliminate the elements of my geometry physically ( i.e: to show formation of the hole). It is kinda complicated but I think is doable. Thanks, -- H. Alavi
Posted: 1 decade ago 2015/03/09 9:00 GMT-4
I've been working on the same simulation as yours lately. Do you have any progress? Are you able to trace the interfaces between liquid-solid and vapor-liquid phases?
Would you please email me at ZCLOVEMIT@163.com if you have some ideas?
Cheers,
Chi Zhang
Hi, I've been working on the same simulation as yours lately. Do you have any progress? Are you able to trace the interfaces between liquid-solid and vapor-liquid phases? Would you please email me at ZCLOVEMIT@163.com if you have some ideas? Cheers, --------- Chi Zhang
Posted: 10 years ago 2016/02/08 23:27 GMT-5
Hi Chi,
Unfortunately i have not had any progress yet. But, I am going to start working on that problem again. do you have any idea how to tackle the issue :)? I will keep you posted as soon as I get any promising results
Cheers,
Chi Zhang
S. H. Alavi
Hi Chi, Unfortunately i have not had any progress yet. But, I am going to start working on that problem again. do you have any idea how to tackle the issue :)? I will keep you posted as soon as I get any promising results Good luck [QUOTE] Hi, I've been working on the same simulation as yours lately. Do you have any progress? Are you able to trace the interfaces between liquid-solid and vapor-liquid phases? Would you please email me at ZCLOVEMIT@163.com if you have some ideas? Cheers, --------- Chi Zhang [/QUOTE] -- S. H. Alavi
Posted: 10 years ago 2016/02/09 3:26 GMT-5
are you aware of the papers available from the following link?
www.comsol.de/papers-presentations?q=laser,melt
There also some dealing with hole formation. I guess it is worth to investigate how they did it. The one from Mr. Bachmann won the best paper award at the COMSOL conferences in Milan 2012.
Hope that helps!
Erik
Erik Bornhöft
37073 Göttingen
Deutschland
Knowledge Base:
COMSOL Blog:
Hi, are you aware of the papers available from the following link? https://www.comsol.de/papers-presentations?q=laser,melt There also some dealing with hole formation. I guess it is worth to investigate how they did it. The one from Mr. Bachmann won the best paper award at the COMSOL conferences in Milan 2012. -- Hope that helps! Best regards, Erik ********************* Erik Bornhöft Senior Technical Sales Engineer COMSOL Multiphysics GmbH Robert-Gernhardt-Platz 1 37073 Göttingen Deutschland Knowledge Base: http://www.comsol.de/support/knowledgebase/browse/900/ COMSOL Blog: http://www.comsol.de/blogs/
