Geometry Units and Convergecne
Does anyone know why changing the "geometry unit" raises convergence issues? For instance, when I change mm to cm, while all other parameters are the same, simulation diverges!
Thank you in advance for your time and consideration!
AR
3 Replies Last Post 2014/08/07 21:19 JST
Jeff Hiller COMSOL Employee
Posted: 1 decade ago 2014/07/28 23:37 JST
Hi Ahmedreza,
It's hard to say specifically without any information about what you're modeling, but certainly the solution of a given problem can be quite different at one scale from what it is at a different scale. For instance, by making your geometry 10 times larger you may transform a laminar flow into a turbulent one. In an EM problem, a mesh that was able to capture a skin layer at one scale may not capture it once the geometry has gone up tenfold. Etc...
Hi Ahmedreza, It's hard to say specifically without any information about what you're modeling, but certainly the solution of a given problem can be quite different at one scale from what it is at a different scale. For instance, by making your geometry 10 times larger you may transform a laminar flow into a turbulent one. In an EM problem, a mesh that was able to capture a skin layer at one scale may not capture it once the geometry has gone up tenfold. Etc... Jeff
Posted: 1 decade ago 2014/08/07 11:31 JST
Hi Ahmedreza,
Hello Jeff,
Thanks a lot for your comment. You are absolutely right, but by scaling down the free stream velocity, I do not let the flow transfer to turbulent regime; I am pretty sure it is still laminar. Actually, I am modeling a fluid-structure interaction problem. Should I post the model here please let me know. Or I can email it to you.
I really appreciate your help.
Sincerely,
AR
AR
[QUOTE] Hi Ahmedreza, It's hard to say specifically without any information about what you're modeling, but certainly the solution of a given problem can be quite different at one scale from what it is at a different scale. For instance, by making your geometry 10 times larger you may transform a laminar flow into a turbulent one. In an EM problem, a mesh that was able to capture a skin layer at one scale may not capture it once the geometry has gone up tenfold. Etc... Jeff [/QUOTE] Hello Jeff, Thanks a lot for your comment. You are absolutely right, but by scaling down the free stream velocity, I do not let the flow transfer to turbulent regime; I am pretty sure it is still laminar. Actually, I am modeling a fluid-structure interaction problem. Should I post the model here please let me know. Or I can email it to you. I really appreciate your help. Sincerely, AR -- AR
Posted: 1 decade ago 2014/08/07 21:19 JST
Feel free to contact COMSOL's technical support to request assistance if your license is eligible for that service: www.comsol.com/support/
Feel free to contact COMSOL's technical support to request assistance if your license is eligible for that service: www.comsol.com/support/ Best, Jeff
