Setting temperature as a variable
Posted 2014/07/24 17:44 JST Heat Transfer & Phase Change 11 Replies
My question is, if it is possible to set the temperature in an area as a variable if the heat source is dependent on the temperature.
As an example I have heat loss in conductor, insulation and sheath. Each of them are temperature dependent. If I let a certain current through the conductor a certain temperature set in each area of the cable. Is there any way to select those temperatures and set as a variable?
Regards
Of corse you can.
You have to define the function, in which temperature appears, as an heat source.
Try to set it as:
Thermal conductivity (W/m*K) * Temperature (K) / Area (1/m^2)
If you click the heat transfer in solids node, at the bottom of the settings of this node there will be a setting 'dependent variables', which should by default say 'Temperature: T'. So 'T' will give you the temperature at every location in your geometry. Now in the electric currents physics, 'current conservation' node you can set the temperature to 'temperature (ht)' instead of 'user defined', and under electrical conductivity you can use 'T' in your expression for the conductivity.
Please tell me if something is not clear in the above explanation.
You need two physics nodes: 'heat transfer in solids' and 'electric currents'. For both physics you set all boundaries as appropriate for your problem. To heat transfer in solids you add a node 'heat source'. You make this a general heat source and change Q from 'user defined' to 'total power dissipation density' to make the resistance losses the heat source.
Dear Pieter,
Thanks for your nice explanation. I would like to simulate the temperature effects on a magnetic sensor. I have done your top instructions! but i have problem in the last sentence, where you say: "under electrical conductivity you can use 'T' in your expression for the conductivity."
I couldn't find this electrical conductivity! Just there is electrical conductivity in "conduction current" tab, so i dont know i have to put on user defined or other options?
I appreciate if you could help me?
I wanted to see what is the effects of temperature changes on my simulation!
Thank you for your kind help. My big problem is when i use Silicon as material for my sensor, i don't have "Temperature" tap in "current conservation" in "Electric Currents" physics!!! So i can't put any value for Silicon temperature.
do you have any suggestion for changing the Silicon temperature?
Suggested Content
- BLOG How to Use State Variables in COMSOL Multiphysics®
- KNOWLEDGE BASE Solving Models with Step Changes to Loads in Time
- FORUM Setting domain temperature
- KNOWLEDGE BASE Out of Memory During Assembly
