Lumped Ports Confusion -- What are they supposed to be?
Posted 2014/08/03 13:22 GMT-4 Low-Frequency Electromagnetics Version 4.4 2 Replies
I am thoroughly confused by ports in COMSOL. How are lumped ports actually solved in the simulation? And what, physically, are they supposed to represent when applied in the Magnetic Fields interface? I would like to use lumped ports to excite my structures because ports in COMSOL allow for the computation of impedances and S-parameters, but the ports never behave as I'd expect them to.
The documentation states that a lumped port "applies a uniform electric field between two metallic boundaries" and that "the excitation at the port can be expressed as a voltage or as a current, or via the connection to a circuit interface." The only equation I can find it discussing is Z=V/I.
I would expect a current-exciting port to drive the specified amount of current through the attached conductor, but this appears to NOT be the case. A lumped port exists in the example model inductor_3d. Changing the specified height/width of that port changes the amount of current that port excites in the attached inductor, even when the specified terminal current for the port is left constant at 1 A. This means the "terminal current" you specify for the port does not actually specify the current excited by that port. So what does "terminal current" actually specify?
On a similar note, what do width/height actually refer to for a user-defined lumped port? In inductor_3d again, for example, the lumped port is defined as the 4 exposed boundaries of a rectangular block. I'd expect the dimensions of this block to match the dimensions of the port in some way, but, again, that is not the case. So what, physically and mathematically, is going on with ports in COMSOL?
2 Replies Last Post 2014/08/05 12:47 GMT-4
