fsi.flexible beam.
Posted 2014/08/10 13:13 GMT-4 Version 4.3a 1 Reply
.. I’m trying to simulate a flexible plate oscillating behind a cylinder with no external load applied on the plate, using COMSOL. I tried to start with one of COMSOL’s examples similar to this work, which is “Vibrating Beam in Fluid Flow (oscillating FSI)”. In this example a beam behind a cylinder subjected to a cyclic point load at the end of the beam was oscillating. The Young Modulus of the beam was 5.6e6.
As a first step toward my own study, I removed the point load and the solution successfully converged. Next, I had to decrease the Young Modulus to match my problem. However, by decreasing the young modulus down to 5.6e4, the solution diverges. I think the reason for that is the generation of inverted mesh. Is that true? How can I sort out this issue and get a convergent solution?
1 Reply Last Post 2014/08/11 10:55 GMT-4
