Lower limit on shear rate.
Hello, I'm using the Fluid-Structure Interaction model and I'm trying to set a lower limit on shear rate. I know under segregated solver you can add "lower limit" funciton but it only seems to work on the dependent variables of the system (p, u_fluid, etc).
Is there a way to make shear rate (fsi.sr_fluid) a dependent variable or make it so I can set a lower limit on shear rate?
0 Replies Last Post 2014/08/20 2:39 JST
Hello Brian Berg
