Thermal coupling in hydro-mechanical analysis for a saturated soil
Posted 2014/09/01 1:42 JST Porous Media Flow, Modeling Tools & Definitions, Parameters, Variables, & Functions 3 Replies
Hi everybody,
I would have some very important questions for you.
I am modeling a saturated soil deposit with the poro-elasticity interface and I would like to couple thermal effects. For this reason, I am also using the heat transfer in porous media interface. However, I would like to ask you if:
1. The solely poroelastocity interface takes into account the thermal induced effects on the mechanical behavior of the soil matrix, i.e., does the tensorial formulation of this interface takes into account thermal induced stress? I have seen that the poroelasticity interface is a sub-module of the solid mechanics one (which can be coupled with thermal effects through the multiphysics interface, both referring to temperature -for the flow in the porous media- and the stress calculation), however, anything is specified about this coupling with this specific module (Ii.e., the multiphysics interface is no more applicable to link the heat transfer and poroelasticity interfaces). May I use all the aforementioned three modules?
2. I have seen that the mass conservation formulation of the poroelasticity interface does not consider the term which expresses the time derivative of temperature multiplied by the relation which expresses the volume filled by water and solid phase through the porosity of the considered soil matrix. Do you know how could I implement this formulation?
Many thanks for your help in this matter,
Alessandro
Alessandro
3 Replies Last Post 2014/09/03 0:38 JST
