limiting a dependent variable to a specified range of values
Posted 2014/09/02 17:17 GMT-4 1 Reply
I am conducting a heat transfer simulation in which I have a dimensionless dependent variable which represents the vapor quality of the coolant fluid.
By definition, vapor quality must take values between zero and one, where a vapor quality of zero represents pure liquid and that of one is pure vapor. Values of less than zero or greater than one have no physical meaning (at least for the purposes of this simulation).
How can I set up the simulation so that the vapor quality is limited to values between 0 and 1? For example, if the simulation, for whatever reason, calculates a vapor quality less than zero, I want the vapor quality to be rewritten as equal to zero. On the other hand, if the simulation calculates a vapor quality greater than one, I want the vapor quality to be written as equal to one.
I want to do this to avoid numerical instability that appears to be caused by vapor quality taking on values less than zero.
Thanks!
Thanks!
1 Reply Last Post 2014/09/08 10:06 GMT-4
