Heat Transfer in Solids Transient behaviour
Posted 2014/09/10 16:39 GMT-4 Heat Transfer & Phase Change, Structural Mechanics Version 4.3b 3 Replies
                                                    Hello Everyone
I am trying to model laser generated acoustic waves in an aluminum disk. Ultimately I plan on using the Thermal Stress physics, but I am starting with just the Heat Transfer portion to make sure the temperature makes sense before running the Thermal Stress Module. The model is 2D axis-symmetric.
To simulate the heating caused by the laser I am applying a body heat source Q = Q(t)*exp(r^2 / s^2)*exp(2z/d). where "s" is the beam radius, "d" is the laser penetration depth and Q(t) is a triangular pulse of 10ns in duration. See the attached PDF for details on the model & boundary conditions.
The resulting temperature profile (see attached pdf) is wrong. The maximum temperature increase is ok (about 180 K at the surface) and the initial time dependence is ok, but then, very large and sharp oscillations appear. These should not be there as there is no more heat being added to the disk and the temperature should keep exponentially falling. Also at some time steps the temperature falls below "ambient" temperature (293.15 K). I have cheked that the source is indeed "dead" at the time the oscillations ocur that the initial temperature and convective fluid temperature are correct, tried smaller relative and absolute tolerances, generalized alpha and BDF time stepping, as well as MUMPS and PARDISO solvers, and all options lead to similar results. I see no physical reason for the sharp temperature increases seen in the response, and I cant seem to figure out what I am doing wrong as this should be a very straightforward model.
Any help is greatly appreciated
3 Replies Last Post 2015/01/19 18:36 GMT-5
