Plasma reaction rate units?
Posted 2014/09/18 21:44 GMT-4 Plasma Physics Version 4.4 1 Reply
in www.comsol.com/community/forums/general/thread/42059/
about cross sections in the plasma module
I got lost in the units of the rate coefficients..
In the manual/help/nomenclature I found:
rj Reaction rate, reaction j [mol/(m^3*s)]
kj Rate coefficient, reaction j [m^3/(mol*s)]
Rk Rate expression, species k [kg/(m^3*s)]
then for the source coefficients:
In the case of rate coefficients, the electron source term is given by
Re=Sum(xj*kj*Nn*ne)
where xj is the mole fraction of the target species for reaction j, kj is the rate coefficient
for reaction j (SI unit: [m^3/s]) and Nn is the total neutral number density (SI unit: [1/m^3]).
(ne electron number density [1/m^3] , i believe)
Here the kj has two different units ? [m^3/(mol*s)] or [m^3/s]
How do I connect the [kg] and [mol] into this unit conversion?
Arigatou gosaimasu
Lukas
nagoya-u
If you are also loading rate coefficients from the COMSOL Boltzmann solver, beware of the units. Last I checked, the MWP interface expects rate coefficients in m^3/(mol*s) while the Boltzmann solver outputs rate coefficients in m^3/s, so be sure to do the conversion.
Luke Gritter
AltaSim Technologies
Re=Sum(xj*kj*Nn*ne)
Arigatou gosaimasu
Lukas
nagoya-u
1 Reply Last Post 2014/09/19 15:45 GMT-4
