Exporting a geometry file (parasolid_binary) using MATLAB Livelink
I would like to export a geometry from COMSOL in parasolid_binary using MATLAB live link ?
You can easily do this from COMSOL desktop, however, I could not do it using the Live link.
Please, provide me the syntax
Thank you in advance
5 Replies Last Post 2016/10/28 16:36 JST
Hello Mohamed Zanaty
Posted: 1 decade ago 2014/11/12 13:34 JST
Hello ,I need too, Could you find this solution? Pleas tell me
Hello ,I need too, Could you find this solution? Pleas tell me Thanks [QUOTE] Hello, I would like to export a geometry from COMSOL in parasolid_binary using MATLAB live link ? You can easily do this from COMSOL desktop, however, I could not do it using the Live link. Please, provide me the syntax Thank you in advance [/QUOTE]
Posted: 1 decade ago 2014/11/12 17:10 JST
yes, you can export your geometry using MATLAB livelink through the following syntax:
model.geom('geom1').export('geomfile.x_b')
BR
Mohamed
yes, you can export your geometry using MATLAB livelink through the following syntax: model.geom('geom1').export('geomfile.x_b') BR Mohamed
Posted: 9 years ago 2016/10/20 23:40 JST
It does not work on COMSOL 5.1 and MATLAB 2013. Any other suggestions?
Gaetano
It does not work on COMSOL 5.1 and MATLAB 2013. Any other suggestions? Gaetano
Jeff Hiller COMSOL Employee
Posted: 9 years ago 2016/10/21 4:36 JST
Reading and writing of Parasolid files requires the CAD Import Module, the Design Module or the LiveLink for CAD products (See www.comsol.com/products/specifications/cad/). Your license may not include these products. You can check which products are included on your license by going to File>Licensed and Used Products.
Reading and writing of Parasolid files requires the CAD Import Module, the Design Module or the LiveLink for CAD products (See https://www.comsol.com/products/specifications/cad/). Your license may not include these products. You can check which products are included on your license by going to File>Licensed and Used Products. Best regards, Jeff
Posted: 9 years ago 2016/10/28 16:36 JST
Hey Jeff,
Thank you for your suggestion. But University license has that package.
I have fixed the problem. It was directory problem. Comsol script helps me a lot.
Best Regards
Gaetano Formato
Hey Jeff, Thank you for your suggestion. But University license has that package. I have fixed the problem. It was directory problem. Comsol script helps me a lot. Best Regards Gaetano Formato
