Data Sets not Updating on Geometry Parametric Sweep
Posted 2014/10/21 16:06 GMT-4 Geometry, Parameters, Variables, & Functions, Studies & Solvers Version 4.4 0 Replies
I have a 2D-Axisymmetric model with a Cut Line data set defined by two points, each with r and z coordinates determined by two parameters such that the cut line is always a fixed distance away from an element of the geometry. I have noticed, however, that while the parameters do indeed change in a parametric sweep, the cut line's position does not. Consequently I am unable to generate the plots I need.
Is there a way to force the cut line to update on each iteration of the sweep, or some other way to get around this issue?
Thomas
Hello Thomas Wester
