Hello, Ivar Kjelberg, help please
Posted 2014/10/23 9:24 GMT-4 Version 4.4 2 Replies
Dear Ivar
I have attached my model so you can see it. My probe is coaxial cable excited from one port with microwave signal. the other end of the coaxial cable will go up to two layers (samples) the first sample will be air and the second sample will be a material with relative permittivity equals to 2.
First, I will fix the end port in the sample 1(AIR) and the frequency equals to 0.1 GHz and calculate the reflection coefficient (S11) at the aperture of the coaxial
Second, I will repeat the first step with frequency equals to 0.3,1 and 3 GHz and calculate the S11 at each frequency.
When I did this the S11 increases with as the frequency increases and this result is wrong because as the frequency increases the S11 should decreases. There is some thing wrong, but I could not discover it.
If this works, I will fix the frequency and make the sweep parametric to move the probe up with step of 0.01mm from the sample1 to sample 2.
I think the problem in the boundary condition.
Please solve this problem for me.
Mabrouka
Mabrouka
2 Replies Last Post 2014/10/27 6:53 GMT-4
