buckling add hidrostatic pressure analisys
Hi everyone
I need modelate two different analisys, but last using results of the first simulation, because first I have plastic buckling in a thin shell tank with external pressure. Practically I have a plastic deformation in a shell and like you know a strain hardening. With the results of this simulation I need to know what is the behaviour of this structure deformation if I subject to this deformation structure to external pressure. My question is possible to use the results of one simulation to another???
2 Replies Last Post 2014/11/06 0:36 JST
Posted: 1 decade ago 2014/11/03 17:11 JST
yes, you can use the simulation results of a given study as the initial condition for a second study. you need to add a new study and then under values of dependent variables, activate initial values of variables solved for, then, select method Solution and study select the study you need to use its results as the initial solution. Also, it is preferred to do the same for the non solved variables.
Hope this will be useful for you
BR
Mohamed
Hi, yes, you can use the simulation results of a given study as the initial condition for a second study. you need to add a new study and then under values of dependent variables, activate initial values of variables solved for, then, select method Solution and study select the study you need to use its results as the initial solution. Also, it is preferred to do the same for the non solved variables. Hope this will be useful for you BR Mohamed
Posted: 1 decade ago 2014/11/06 0:36 JST
Mohamed, do you have some tutorial to this Topics???
Flavio
Mohamed, do you have some tutorial to this Topics??? Flavio Thanks
