Error 7111: Singular matrix
Posted 2010/04/24 19:38 JST 1 Reply
Hi all,
I'm trying to solve a simple hyperelastic cube (Neo-Hookean) that contains two hyperelastic fibers.
I'm using a 3D Structural mechanics - Solid, Stress-Strain module.
1) At first,
a) I applied one set of periodic boundary conditions from one face of the cube to the opposite face.
b) Then I added constraints on 3 points (using "point settings").
c) and I added constraints on the all remaining boundaries (using "boundary settings").
This one worked!
2) However, when I chose two more (opposite) faces and applied one more set of periodic boundary conditions on them (instead of the boundary constraints that were applied on them in the last case), I received the following error:
Details:
Exception:
com.femlab.jni.FlNativeException: Singular matrix
Singular matrix
Stack trace:
at umfpack.cpp, row 597, ()
at com.femlab.solver.FlSolver.femStatic(Native Method)
at com.femlab.solver.FemStatic.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
3) The periodic boundary conditions are supposed to be correct - I'll explain: When I used a simple cube- without the fibers and applied both sets of periodic boundary conditions on 4 faces plus adding constraints on 3 points - this was solved! The error occurs only when adding the fibers... Is this a meshing problem?
What do you suggest I should do in this case?
Thank you in advance,
Tal
1) At first,
This one worked!
Details:
Exception:
Singular matrix
Stack trace:
Tal
1 Reply Last Post 2010/04/24 20:56 JST
