Accurate inflow/outflow calculation
Hi, I'm using the Free&Porous workflow, but the question is also applicable to Navier-Stokes.
I have an inlet and use NormalVelocity boundary condition which, it seems sets up a Lagrange multiplier to enforce u = u_0. No problem.
But when I do an integral over the inlet surface to check that total fluid-in matches the desired actual fluid in, then I have a big error (>20%). Yes, I could mesh more finely....
But I thought I remember a "trick" for accurate calculations of flow across a surface. Isn't this equal to a Lagrange multiplier or something? Maybe I am misremembering.
Does this ring a bell with anyone??
Thanks, John
2 Replies Last Post 2014/11/21 2:03 JST
Jeff Hiller COMSOL Employee
Posted: 1 decade ago 2014/11/17 23:05 JST
Hi John,
Maybe this is the technique you remember: www.comsol.com/support/knowledgebase/973/
Hi John, Maybe this is the technique you remember: http://www.comsol.com/support/knowledgebase/973/ Best, Jeff
Posted: 1 decade ago 2014/11/21 2:03 JST
Thanks, yes, Jeff, this was what I had in mind. My problem is linear. If I use velocity constraint on u in the fp interface then [I think] this is established as Dirichlet u = u0.
To type in some exemplary values
computed surface integral of fp.U across inlet = 0.006 m^3/s
computed integral of fp.U0 = 0.007 m^3/s
computed inlet pressure is 500psi
So that raises the fun question of whether the infinitely converged answer for the pressure drop would be 500 * 0.007/0.006
If so, then I can simply do nothing! :-)
Alternatively, if I choose Dirichlet on p=500 then I get computed surface integral on fp.U of 0.006 m^3/s so I don't know that I've got anything wrong.
I'll try a weak constraint on u=u0 next
Thanks, John
Thanks, yes, Jeff, this was what I had in mind. My problem is linear. If I use velocity constraint on u in the fp interface then [I think] this is established as Dirichlet u = u0. To type in some exemplary values computed surface integral of fp.U across inlet = 0.006 m^3/s computed integral of fp.U0 = 0.007 m^3/s computed inlet pressure is 500psi So that raises the fun question of whether the infinitely converged answer for the pressure drop would be 500 * 0.007/0.006 If so, then I can simply do nothing! :-) Alternatively, if I choose Dirichlet on p=500 then I get computed surface integral on fp.U of 0.006 m^3/s so I don't know that I've got anything wrong. I'll try a weak constraint on u=u0 next Thanks, John
