Script (COMSOL 3.4)
Posted 2010/05/08 0:21 GMT-4 0 Replies
I'm working in COMSOL 3.4 and I'm using the Script to solve my problem. I basically solve for two application modes that are independent by using "initial value expression" in the initial value tab on solver manager. Then I use that solution (change "initial value expression" to "current solution") to solve for all application modes. I created the script in this way. What happens is that apparently the problem solves well for a first time but if I change parameters and run it again by clicking the "equal" sign in the toolbar the solution changes drastically (and it changes over and over even if I plug back the initial parameters). Is it has to do with the field "Values of variables not solver for and linearization point" on the solver manager? There I have selected "use setting for initial value frame" through all the solution process.
Any help is kindly appreciated.
-Omar
Hello Omar Canales
