Integration over limited region
I want to calculate an integral of a function only on part of a subdomain.
For example
g(x)=integral of f(x') from x'=0 to x'=x
I think an integration coupling variable it is not possible since it always integrates over the hole subdomain.
Thanks for your help,
Oliver
9 Replies Last Post 2012/03/28 5:40 GMT-4
Posted: 2 decades ago 2010/05/10 9:48 GMT-4
I believe the only way currently possible is to split your domains so you have internal boundaries. Then you can integrate on the part of the domain you want.
Posted: 2 decades ago 2010/05/10 15:22 GMT-4
I would say too that Danial has right, the easiest is to sudivide your domains or boundaries. But if you know the coordinate limits you can also get around with a bolean expression of the type
Integr_variable = mises_smsld*((x-x0)^2+(y-y0)^2<=R^2)
where R is a constant, but you should then also normalise over the
Area=1*((x-x0)^2+(y-y0)^2<=R^2)
Have fun Comsoling
Hi I would say too that Danial has right, the easiest is to sudivide your domains or boundaries. But if you know the coordinate limits you can also get around with a bolean expression of the type Integr_variable = mises_smsld*((x-x0)^2+(y-y0)^2
Posted: 2 decades ago 2010/05/10 16:20 GMT-4
Have fun Comsoling
Everyday something new to learn. great tip Ivar.
[QUOTE] Hi I would say too that Danial has right, the easiest is to sudivide your domains or boundaries. But if you know the coordinate limits you can also get around with a bolean expression of the type Integr_variable = mises_smsld*((x-x0)^2+(y-y0)^2
Posted: 2 decades ago 2010/05/10 16:29 GMT-4
Hi Ivar and Daniel,
thank you for your answers.
Since I wanted to have a continuous function it does not work with the subdomain.
But I found an other option which seems to work.
I defined an integration coupling variable as.
g(x) = f * (dest(x')>=x')
this seems to be what I wanted.
Oli
Hi Ivar and Daniel, thank you for your answers. Since I wanted to have a continuous function it does not work with the subdomain. But I found an other option which seems to work. I defined an integration coupling variable as. g(x) = f * (dest(x')>=x') this seems to be what I wanted. Best regards, Oli
Posted: 2 decades ago 2010/05/11 1:16 GMT-4
If I understand you well you are also then playing with defined "destinations" and not just "global", otherwise you will get many items no ?
Perhaps not important with todays computer power
have fun Comsoling
Hi If I understand you well you are also then playing with defined "destinations" and not just "global", otherwise you will get many items no ? Perhaps not important with todays computer power have fun Comsoling Ivar
Posted: 2 decades ago 2010/05/11 3:53 GMT-4
Yes it is quite time consument...
But with your advice I can avoid the problem of defining new subdomains, but it just works for a certain value of R or?
So in particular I want to calculate a local generation rate depending on an integral from one boundary to that local point. To use your method I would have to change R localy - is that possible?
But then it is not fast than with dest(x), or?
I do have fun Comsoling!
Oli
Hi, Yes it is quite time consument... But with your advice I can avoid the problem of defining new subdomains, but it just works for a certain value of R or? So in particular I want to calculate a local generation rate depending on an integral from one boundary to that local point. To use your method I would have to change R localy - is that possible? But then it is not fast than with dest(x), or? I do have fun Comsoling! Oli
Posted: 1 decade ago 2010/11/11 16:24 GMT-5
Hi Oliver,
I think I have a similar problem with you. Instead of integrating over a whole boundary/line, I want to integrate f(x) from x=0 to x itself over arbitrary line (probably only lines paralleled to x axis) within a subdomain. Did f * (dest(x')>=x') in "integration coupling variables" work out finally? Did you choose subdomain variable or boundary variable? Your help will be greatly appreciated.
Fan
Hi Oliver, I think I have a similar problem with you. Instead of integrating over a whole boundary/line, I want to integrate f(x) from x=0 to x itself over arbitrary line (probably only lines paralleled to x axis) within a subdomain. Did f * (dest(x')>=x') in "integration coupling variables" work out finally? Did you choose subdomain variable or boundary variable? Your help will be greatly appreciated. Thanks, Fan
Posted: 1 decade ago 2010/11/15 7:48 GMT-5
Hi Fan,
it worked fine at the end and I chose subdomain varaiables. So just try it and perhaps play around with the integral definitions in order to get some feeling for this.
Best Regards,
Oliver
Hi Fan, it worked fine at the end and I chose subdomain varaiables. So just try it and perhaps play around with the integral definitions in order to get some feeling for this. Best Regards, Oliver
Posted: 1 decade ago 2012/03/28 5:40 GMT-4
Hi.
I have a somewhat related problem:
on a whole 3D (x, y, z) domain, I want to define a value f(x)=integral over y and z of k(x,y,z)
With k beeing my turbulent cinetic energy.
How can I do this?
Hi. I have a somewhat related problem: on a whole 3D (x, y, z) domain, I want to define a value f(x)=integral over y and z of k(x,y,z) With k beeing my turbulent cinetic energy. How can I do this?
