How to automatically move component within design when solving instead of changing geometry...
Posted 2010/05/11 16:42 GMT-4 1 Reply
Hello, I'm trying to figure out some means of moving a bubble of liquid suspended in a different liquid over some electrodes and then looking at impedance as the bubble moves laterally....is there an easy method of automating this type of movement, or do I have to go through and manually alter the position of the bubble and run a stationary simulation for every value of x needed?
More specifically, I'm trying out some tests with the COMSOL electric impedance sensor model for version 3.5. In this model, the conductivity of the bulk solution outside the air cavity is defined by the equation sig_bulk*(((x-x0)^2+(y-y0)^2)>r0^2, is there a means of also defining the conductivity of the air cavity such that sigma is defined for <r0^2? And then in doing so, can I see the position of the newly defined air cavity change and the resulting waveforms plotted for a range of x-values?
Thanks for any help,
Eric
Eric
1 Reply Last Post 2010/05/12 16:37 GMT-4
