Mikic elastic correlation error in thermal contact node
Posted 2015/01/07 15:12 GMT-5 Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.0 0 Replies
Division by zero.
- Function: /
Failed to evaluate variable.
- Variable: comp1.ht.tc1.Econtact
- Defined as: ((down(comp1.ht.tc1.Eequ)*up(comp1.ht.tc1.Eequ))/(((1-(up(comp1.ht.tc1.nuequ)^2))*down(comp1.ht.tc1.Eequ))+(up(comp1.ht.tc1.Eequ)*(1-(down(comp1.ht.tc1.nuequ)^2)))))
- Expression: if(((comp1.ht.tc1.Tn==0)||(comp1.ht.tc1.Econtact==0)),0,((comp1.ht.tc1.Tn*1.4142135623730951)/(comp1.ht.tc1.m_asp*comp1.ht.tc1.Econtact)))
- Variable: comp1.ht.tc1.TnRel
- Defined as: if(((comp1.ht.tc1.Tn==0)||(comp1.ht.tc1.Econtact==0)),0,((comp1.ht.tc1.Tn*1.4142135623730951)/(comp1.ht.tc1.m_asp*comp1.ht.tc1.Econtact)))
Failed to evaluate operator Jacobian.
- Operator: if
- Geometry: geom1
- Boundary: 93
- Feature: Stationary Solver 1 (sol1/s1)
I don't see anything wrong with my inputs, though. I put in values for E and the Possion ratio for the Weighted Harmonic Mean, but it treats Eup and Edown as 0? I have no idea where to input those values. I would think it pulls the values from the material properties. In any case, what exactly is it that I am filling in when I put in the value for E and the Poisson ratio in that node?
The boundaries I'm defining are simple -- just a rectangle against another rectangle.
Hello Damian Rivas
