How to do a Component Coupling with a varying parameter
I've defined an integration over a region using the Integration component coupling operator, call it regionint(). Then I create a variable regionint(something(x,y,z,foo)) where foo is a global parameter. I'd like to vary foo to see a bunch of different global evaluations of this regionint(), but changing foo doesn't change the global evaluation result unless I "update solution", which is a long and tedious process.
I guess what I want to do is a post-processing sweep of foo. How is this done?
0 Replies Last Post 2015/01/17 1:17 JST
Hello Chris Nadovich
