COMSOL with MATLAB Error
Bit of a boring generic question I'm afraid but if anyone has come across this error any help would be appreciated.
I've been trying to get the COMSOL with MATLAB livelink working and after some trials managed to get the shortcut to finally appear :). however I can't seem to get it to work as i keep getting an error:
com.comsol.util.exceptions.FlException: Unable to get the user manager
I think it could be a path problem as it was a problem before hand with having MATLAB installed on the D:\.
However when i run D;\COMSOL40\Bin\win32\comsol matlab
I can get it to load up both however fail to actually get it to run any of my models as I get an error:
Exception:
com.comsol.util.exceptions.FlException: Launching COMSOL Server automatically is currently not supported
Stack trace:
at com.comsol.model.clientserver.ClientManagerImpl.launchServer(Unknown Source)
at com.comsol.model.util.ModelManager.create(Unknown Source)
at com.comsol.model.util.ModelUtil.create(Unknown Source)
another possible path problem?
any help is appreciated.
Kind Regards MF
22 Replies Last Post 2011/11/01 17:57 JST
Posted: 2 decades ago 2010/05/28 14:11 JST
Hi not evident to tell
but have you checked/studied the installation guide of comsol, ensured that your comsol.ini files have the correct matlab path, and there are a few ways to launch matlab an comsol, try them out.
Finally there is also the version compatibility between matlab and COMSOL. Pls check also the forum (do a search) and the knowledge base
Hope this helps
Hi not evident to tell but have you checked/studied the installation guide of comsol, ensured that your comsol.ini files have the correct matlab path, and there are a few ways to launch matlab an comsol, try them out. Finally there is also the version compatibility between matlab and COMSOL. Pls check also the forum (do a search) and the knowledge base Hope this helps Ivar
Posted: 2 decades ago 2010/06/03 1:00 JST
Hi Micheal,
Just in case you haven't solved this yet, maybe this will help:
I just installed v4 with Matlab R2010a and was getting the same error. After fiddling with a bunch of stuff, I ended up running comsolserver (no space) which prompted me for a username/password which I made up and entered. After I exited this program (typed 'close'), I then tried the 'COMSOL with MATLAB' star menu shortcut again and everything worked fine. Not sure what I accomplished, but hey, solved my problem.
FYI, I installed on a Linux Machine (Ubuntu 10.4) and Windows (Vista SP2) and had the same problem on each. The above fixed both instances.
Hi Micheal, Just in case you haven't solved this yet, maybe this will help: I just installed v4 with Matlab R2010a and was getting the same error. After fiddling with a bunch of stuff, I ended up running comsolserver (no space) which prompted me for a username/password which I made up and entered. After I exited this program (typed 'close'), I then tried the 'COMSOL with MATLAB' star menu shortcut again and everything worked fine. Not sure what I accomplished, but hey, solved my problem. FYI, I installed on a Linux Machine (Ubuntu 10.4) and Windows (Vista SP2) and had the same problem on each. The above fixed both instances.
Posted: 2 decades ago 2010/06/03 3:24 JST
I contacted a COMSOL rep about this issue today. It looks like Kyle is on the right track:
www.comsol.com/support/knowledgebase/1071/
I contacted a COMSOL rep about this issue today. It looks like Kyle is on the right track: http://www.comsol.com/support/knowledgebase/1071/
Posted: 2 decades ago 2010/06/14 0:16 JST
hi,
I'm also trying to livelink comsol and matlab, and got the same errors.
however, after I changed the path in the shortcut and entered a username and password, it started matlab alone, without comsol.
I closed matlab and used the shortcut, and again it opened only matlab, without asking for a username.
does anybody know what I'm supposed to do?
thank you,
yael.
hi, I'm also trying to livelink comsol and matlab, and got the same errors. however, after I changed the path in the shortcut and entered a username and password, it started matlab alone, without comsol. I closed matlab and used the shortcut, and again it opened only matlab, without asking for a username. does anybody know what I'm supposed to do? thank you, yael.
Posted: 2 decades ago 2010/06/14 14:26 JST
as it is stated in the doc, you should ONCE first launch the server alone and provide your username password, then you can launch comsol server and matlab. hey link via a localhost tcpip link and the server needs to log in, via its console. It must be done "by hand", at least once, then normally matlab starts OK, provided that the matlab path is correclty entered in the ini files. This operation might be required after a new patch update too I believe
have fun Comsoling
Hi as it is stated in the doc, you should ONCE first launch the server alone and provide your username password, then you can launch comsol server and matlab. hey link via a localhost tcpip link and the server needs to log in, via its console. It must be done "by hand", at least once, then normally matlab starts OK, provided that the matlab path is correclty entered in the ini files. This operation might be required after a new patch update too I believe have fun Comsoling Ivar
Posted: 2 decades ago 2010/06/14 18:10 JST
thank you for your response,
but as I said, when I launch "comsol 4.0 with matlab" only matlab starts, and comsol does not.
have you encountered this problem before?
yael.
thank you for your response, but as I said, when I launch "comsol 4.0 with matlab" only matlab starts, and comsol does not. have you encountered this problem before? yael.
Posted: 2 decades ago 2010/06/14 20:15 JST
Yael,
The "Comsol 4.0 with Matlab" function is meant to only start Matlab with Comsol functionality. All the functions needed to create/run/analyze models and simulations are loaded into this instance of Matlab. A Comsol window will not open with this command. This is different than with Comsol <4 where a Comsol window would be opened.
-Kyle
Yael, The "Comsol 4.0 with Matlab" function is meant to only start Matlab with Comsol functionality. All the functions needed to create/run/analyze models and simulations are loaded into this instance of Matlab. A Comsol window will not open with this command. This is different than with Comsol
Posted: 2 decades ago 2010/06/14 20:35 JST
I have tried using the KB suggestion, changing comsol.exe to comsolserver.exe. I did get a DOS prompt asking me to create a user/pw. Having done so nothing happened. Subsequent attempts to launch Comsol with Matlab yields a DOS window saying "COMSOL 4.0 started listening on port 2036", however nothing else happens.
Comsol.ini inside the Comsol install dir reads the correct location of the Matlab folder. I am using Matlab R2008b, Comsol 4.0 version 935 (patched), Windows XP 64 bit.
/Samuel
[QUOTE] I contacted a COMSOL rep about this issue today. It looks like Kyle is on the right track: http://www.comsol.com/support/knowledgebase/1071/ [/QUOTE] I have tried using the KB suggestion, changing comsol.exe to comsolserver.exe. I did get a DOS prompt asking me to create a user/pw. Having done so nothing happened. Subsequent attempts to launch Comsol with Matlab yields a DOS window saying "COMSOL 4.0 started listening on port 2036", however nothing else happens. Comsol.ini inside the Comsol install dir reads the correct location of the Matlab folder. I am using Matlab R2008b, Comsol 4.0 version 935 (patched), Windows XP 64 bit. /Samuel
Posted: 2 decades ago 2010/06/14 20:45 JST
/Samuel
Samuel,
Your problem may be that R2008b is not supported by Comsol 4.0, looks like only R2009b and R2010a are supported.
www.comsol.com/products/requirements/windows/
[QUOTE] I am using Matlab R2008b, Comsol 4.0 version 935 (patched), Windows XP 64 bit. /Samuel [/QUOTE] Samuel, Your problem may be that R2008b is not supported by Comsol 4.0, looks like only R2009b and R2010a are supported. http://www.comsol.com/products/requirements/windows/
Posted: 2 decades ago 2010/06/14 21:15 JST
Hi Kyle,
Thank you for the suggestion, however, having installed Matlab R2010a, the Comsol/Matlab interface still hangs at the same step as previously reported...
/Samuel
Hi Kyle, Thank you for the suggestion, however, having installed Matlab R2010a, the Comsol/Matlab interface still hangs at the same step as previously reported... /Samuel
Posted: 2 decades ago 2010/06/14 21:20 JST
Hi Michael,
I also have the problem that I miss the COMSOL and MATLAB shortcut.
How did you get it to appear?
Regards, Sabine
Hi Michael, I also have the problem that I miss the COMSOL and MATLAB shortcut. How did you get it to appear? Regards, Sabine
Posted: 2 decades ago 2010/06/14 21:37 JST
Hy,
I've got following information from support.:
"COMSOL with MATLAB in version 4.0 does no longer start a COMSOL GUI by typing "comsol" in the MATLAB prompt. "
See documentation: LiveLink™ for
MATLAB User's Guide. --> Getting started. (llmatlab_ug.pdf).
Roland Martin
Hy, I've got following information from support.: "COMSOL with MATLAB in version 4.0 does no longer start a COMSOL GUI by typing "comsol" in the MATLAB prompt. " See documentation: LiveLink™ for MATLAB User's Guide. --> Getting started. (llmatlab_ug.pdf). Roland Martin
Posted: 2 decades ago 2010/06/15 0:23 JST
first of all, thank you all very much for your help!
kyle, you're saying that comsol is not supposed to start at all?
I'm solving (or trying to solve) a heat transfer problem, with one of the material's properties calculated from a matlab function.
when I worked with COMSOL 3.5a, it started the two softwares simultaneously, and all I had to do is to insert the matlab function name to the property field and it worked, with no need to work with matlab myself during the run.
can't I do the same with COMSOL 4.0?
I saw that I can insert a matlab function to comsol, but it just doesn't recognize it when I start COMSOL normally, obviously.
thanks,
yael.
first of all, thank you all very much for your help! kyle, you're saying that comsol is not supposed to start at all? I'm solving (or trying to solve) a heat transfer problem, with one of the material's properties calculated from a matlab function. when I worked with COMSOL 3.5a, it started the two softwares simultaneously, and all I had to do is to insert the matlab function name to the property field and it worked, with no need to work with matlab myself during the run. can't I do the same with COMSOL 4.0? I saw that I can insert a matlab function to comsol, but it just doesn't recognize it when I start COMSOL normally, obviously. thanks, yael.
Posted: 2 decades ago 2010/06/15 15:50 JST
Hi Roland,
I'm fine with COMSOL not starting, however, I would like Matlab to do so - staring at a DOS window seems an unprofitable waste of time:)
/Samuel
Hi Roland, I'm fine with COMSOL not starting, however, I would like Matlab to do so - staring at a DOS window seems an unprofitable waste of time:) /Samuel
Posted: 1 decade ago 2010/09/11 20:29 JST
Hi Kyle Wilt,
Thanks so much for your advice.
Hi Kyle Wilt, Thanks so much for your advice.
Posted: 1 decade ago 2010/09/11 20:38 JST
have you checked the new "external function import" in V4.
You can define an external functions in the Global Definitions sub nodes.
I havent had time to test it yet but I would appreciate to hear how well it works ;)
Hi have you checked the new "external function import" in V4. You can define an external functions in the Global Definitions sub nodes. I havent had time to test it yet but I would appreciate to hear how well it works ;) -- Good luck Ivar
Posted: 1 decade ago 2010/12/08 17:30 JST
Hello Sabine,
I do have the same problem with finding the comsol with matlab shortcut. And I am also very interested in how Micheal did solve the problem.
I got matlab 2009b installed and I have the matlab livelink included in comsol 4.0a, but there is no shortcut in the windows startmenu.
Then I tried to create a shortcut myself which executes following command: comsolserver.exe matlab.
A window opened and I typed in a username and password. Afterwards nothing happens... normally matlab should start, right? In the comsol.ini I couldn´t find an entry, which defines the patch to matlab. Maybe Ivar knows how to set the path correctly???
best regards
Oliver
Hello Sabine, I do have the same problem with finding the comsol with matlab shortcut. And I am also very interested in how Micheal did solve the problem. I got matlab 2009b installed and I have the matlab livelink included in comsol 4.0a, but there is no shortcut in the windows startmenu. Then I tried to create a shortcut myself which executes following command: comsolserver.exe matlab. A window opened and I typed in a username and password. Afterwards nothing happens... normally matlab should start, right? In the comsol.ini I couldn´t find an entry, which defines the patch to matlab. Maybe Ivar knows how to set the path correctly??? best regards Oliver
Posted: 1 decade ago 2010/12/08 21:24 JST
check also the KB (knowledge base) of COMSOL on their main site, there are several instructios regarding matlab link issues
Hi check also the KB (knowledge base) of COMSOL on their main site, there are several instructios regarding matlab link issues -- Good luck Ivar
Posted: 1 decade ago 2011/09/16 1:51 JST
Not sure if this is still related to this problem but,
I have on occassion got erros which contain the 'Unkown Source' text, though I am not 100% sure I beleive on some occassions it is simply a license issue. When this occurs I often remote desktop through to my university computer and I think Comsol supports local 'Mouse Click' operations but not remote desktop ones for certain licenses.
I could be wrong, but when do similar things directly, using a mouse Comsol has no problem, only when I remote desktop.
Regards Mike F
Not sure if this is still related to this problem but, I have on occassion got erros which contain the 'Unkown Source' text, though I am not 100% sure I beleive on some occassions it is simply a license issue. When this occurs I often remote desktop through to my university computer and I think Comsol supports local 'Mouse Click' operations but not remote desktop ones for certain licenses. I could be wrong, but when do similar things directly, using a mouse Comsol has no problem, only when I remote desktop. Regards Mike F
Posted: 1 decade ago 2011/11/01 17:54 JST
Hi Micheal,
[QUOTE] Hi Micheal, Just in case you haven't solved this yet, maybe this will help: I just installed v4 with Matlab R2010a and was getting the same error. After fiddling with a bunch of stuff, I ended up running comsolserver (no space) which prompted me for a username/password which I made up and entered. After I exited this program (typed 'close'), I then tried the 'COMSOL with MATLAB' star menu shortcut again and everything worked fine. Not sure what I accomplished, but hey, solved my problem. FYI, I installed on a Linux Machine (Ubuntu 10.4) and Windows (Vista SP2) and had the same problem on each. The above fixed both instances. [/QUOTE]
Posted: 1 decade ago 2011/11/01 17:56 JST
Exception:
Stack trace:
Kind Regards MF
[QUOTE] Hi, Bit of a boring generic question I'm afraid but if anyone has come across this error any help would be appreciated. I've been trying to get the COMSOL with MATLAB livelink working and after some trials managed to get the shortcut to finally appear :). however I can't seem to get it to work as i keep getting an error: com.comsol.util.exceptions.FlException: Unable to get the user manager Messages: Unable to get the user manager I think it could be a path problem as it was a problem before hand with having MATLAB installed on the D:\. However when i run D;\COMSOL40\Bin\win32\comsol matlab I can get it to load up both however fail to actually get it to run any of my models as I get an error: Exception: com.comsol.util.exceptions.FlException: Launching COMSOL Server automatically is currently not supported Messages: Launching COMSOL Server automatically is currently not supported Stack trace: at com.comsol.model.clientserver.ClientManagerImpl.launchServer(Unknown Source) at com.comsol.model.util.ModelManager.create(Unknown Source) at com.comsol.model.util.ModelUtil.create(Unknown Source) another possible path problem? any help is appreciated. Kind Regards MF [/QUOTE]
Posted: 1 decade ago 2011/11/01 17:57 JST
the first time you run the matlab link in server mode you need to give a user name and password, as the software calls loops around via the OS. You might also get a firewall warning "allow this", It's all written in the user guide I believe
Hi the first time you run the matlab link in server mode you need to give a user name and password, as the software calls loops around via the OS. You might also get a firewall warning "allow this", It's all written in the user guide I believe -- Good luck Ivar
