Comsol v4 license with older versions
I have received my Comsol v4 and eager to install it, however, I have lots of models which run under v3.5a and my question is, if I replace the old license file in our license server with the new one, can I still be able to run the older versions?
Thanks in advance,
Onur
5 Replies Last Post 2010/05/28 11:13 GMT-4
Posted: 2 decades ago 2010/05/28 3:13 GMT-4
As a first step kb is the best: www.comsol.com/support/knowledgebase/browse/4/
As a first step kb is the best: http://www.comsol.com/support/knowledgebase/browse/4/
Posted: 2 decades ago 2010/05/28 7:45 GMT-4
Yes, I have been there before posting, with no useful results.
Posted: 2 decades ago 2010/05/28 8:10 GMT-4
The license is an ASCII file, you just need to copy and past the new one into the older license server file. In that way you can keep using both versions.
I hope it helps!
Cheers
Hi, The license is an ASCII file, you just need to copy and past the new one into the older license server file. In that way you can keep using both versions. I hope it helps! Cheers
Posted: 2 decades ago 2010/05/28 8:41 GMT-4
Thank you for your input! I will try.
Posted: 2 decades ago 2010/05/28 11:13 GMT-4
Indeed, but withOUT copying the "server ... use server" lines, they should only appear once at the top
Have fun Comsoling
Hi Indeed, but withOUT copying the "server ... use server" lines, they should only appear once at the top Have fun Comsoling Ivar
