Surface reaction rate problem
Posted 2010/06/01 5:14 GMT-4 7 Replies
The problem is that the reaction is fast on the points where mesh boundaries hit the surface and it is slow between those mesh points. I have changed the mesh several times and it is always the same situation.
I have no idea what could cause this problem. Could anyone help me?
I have not changed any setting in the stabilization part of the subdomain settings, so no artificial diffusion. I did try to read something about those from the manuals, but didn't get the idea what to do.'
And yes, there are high concentration gradients in the model so I made very fine mesh in those areas.
These are based on my own experience, so it may not be valid completely in your case.
First of all, my model is steady-state, so no time-steps. I have been wondering is there any sense to use the turbulence model in a steady-state problem... but I don't know.
Now I tried few different settings for artificial diffusion, but they seem to make the solution oscillate. I read the part of the stabilization methods in the manual, but I'm still very confused about what settings I really should use. It would help if I found an example about turbulent modelling with molecular diffusion, but I didn't find any.
As long as you do not tell us tech details of your model all we can do is guessing. Above is for Comsol 4.
I didn't get it at first because I was using logarithmic concentrations instead of real concentrations to avoid negative concentrations. Now with the older model I see that streamline diffusion helped a lot. Maybe I will now just try to ignore the negative (-1e-7) concentrations from the numerical noise or add some more reactants...
Thank you very much for the help.
Also, take care of Artificial diffusion (AD). Try different AD parameter values to see how much it is changing your solution. It can be a real beast sometimes :-)
